jkok7
I'm getting a 200 amp Battery Isolator today. I have the Kinetik 2400, but I'm not sure that's the enough juice for that amp. The Mmats 3500.1 draws like 300 amps. I still can't turn the gain more than a 3rd of the way up without getting that hard "Pulsating" action from my subs from the amp. So I think I need another battery in addition to what I already have. Just to fill you in, I have a Titanium Autocraft Battery under the hood the specs are: 875 Cranking Amps, 700 Cold Cranking Amps & 95 Reserve Capacity, Big 3 0 Gauge, 200 Amp Alternator, Kinetik 2400 & an Xstatic Super 100 (35 Farads).
When I try to cut the gain past a 3rd of the way up at 1 ohm, my subs pulsate and my lights dim along with the pulsating.
I called Mmats today and he said not to use a battery isolator as it makes it to where you only charge one battery at a time. First he said that I should run a test on both batteries. Then He said the battery under the hood should be the same size and same brand. Or at least the same type of non-spillage battery wi the the same amount or similar power.
Any help would be appreciated.
