mustanggt5330
and i didnt do the ground from the block the to frame, just from the battery to the frame. will that make a difference?
Fuses protect the wire not the electronics on either end //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gifdo you have to??......nobody is forcing you to //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
But the fuse is there to protect the battery from blowing the hell up. So yes, it is definitely recommended to put a fuse in there just in case.
Wire Gauge Recommendedit would seem that the wire guide is no longer stickied does anyone know where it was?
Thanks that is what I was looking forWire Gauge RecommendedMaximum Fuse Size
00 awg 400 amps
0 awg 325 amps
1 awg 250 amps
2 awg 200 amps
4 awg 125 amps
6 awg 80 amps
8 awg 50 amps
10 awg 30 amps
12 awg 20 amps
14 awg 15 amps
16 awg 7.5 amps
These are the recommended maximum fuse ratings for the corresponding wire size. Using a smaller fuse than what's recommended here will be perfectly safe.
http://www.bcae1.com/
Basic Car Audio Electronics
uh huhIf you are gonna fuse the alt wire you might as well throw 2 fuses one at the battery and one at the alot to protect it from grounding out. Because the only thing 1 fuse would protect is
No.But the fuse is there to protect the battery from blowing the hell up. So yes, it is definitely recommended to put a fuse in there just in case.
