Do Nak subs bump subwoofer question inside
jhall05
NAKAMICHI SP-W1200D
specs are
Diameter: 12" 305mm
Sensitivity: 88dB
Power Handling: Watts RMS: 450 Watts Watts Peak: 650 Watts
Frequency Response: 20Hz-500Hz
Nominal Impedance: 2 x 6 Ohms Cone Material: Pulped Paper Basket Material: Aluminum Surround Material: 2.25" Rubber Spider Material: Nomex Magnet Weight: 120oz.
Voice Coil: Dual Free-Air Resonance (Fs): 28.15Hz Mechanical Dampening (Qms): 6.297 Electrical Dampening (Qes): .742 Total System Dampening (Qts): .663 Voice Coil DC Resistance (Re): 5.6 Ohms (Dual) Equivalent Acoustic Volume (Vas): 74.504 Liters Effective Diaphragm Area (Sd): 49.087 sq. meter Linear Coil Excursion (Xmax): 12.5mm Half Space Output Level (SPL): 88dB Energy Bandwidth Product (EBP): 43 Mass of the Moving System
if anyone wants one dont know if there good ive read mixed reviews i got a great deal at http://www.electronicgiant.net/catalog/product_info.php?manufacturers_id=154&products_id=7425&osCsid=939f1d77109ed19889302165464244aa
what kind of sub box do i need for it though i cant find it anywhere and i want to make sure i get the thing and make everything perfect.
Given the linear excursion, it should have adequate output for most music genre's, but I wouldn't expect to win any SPL battles with it.
Given the high Qts and low EBP, a sealed box is what it's best suited for.
i dont plan on winning a contest i plan on being able to just play it loud and clear and feel like im still at the club when im going and leaving.
so a sealed box with what cubic size. i dont understand how to measure that.
basshead tips try out
the justin timberlake track - sexyback very nicing sounding in a jl audio 13 w7 aswell as for the rap might want to try out joe budden - stuntn
jhall05
jhall05
Fairfield County, CT
jhall05
AJ (ACE)
    Jun 28, 2026
