BlackHawk99
Hi. I wanted to know if you think I really need a HO alternator. I have a 2001 Toyota Camry LE V6 with less than 50,00 original miles on it. It has what I believe is a 80 amp stock alternator. Right now I have a 4 channel class AB amp. It's a Rockford Fosgate Power T600-4 (100 watts x 4 @ 4 ohm) with 2 channels powering a front set of components. I'm getting a new class D mono amp this week. Once I get it, 2 channels of the T600-4 will be retired. The new amp will be the Rockford Fosgate Power T1000-1bdCP and it will power a sub or two. It does 700 watts x 1 @ 4 ohm or 1,000 watts x 1 @ 2 ohm. I will not run it below 2 ohm. I may even get a JL Audio sub that is 3 ohm, but I haven't decided. Would that 3 ohm load throw things off in some way? I am also looking hard at a Boston SPG555, Boston G5 or G3 sub. My headunit is a Pioneer AVH-P3200BT DVD receiver. Front Speakers: Focal 165 VB components. I also have a Rockford Fosgate Punch PEQ Equalization Remote (controls bass level from front seat). I've been told and also read that as long as I don't go over 2,000 watts the stock alternator will be fine with this system. Others disagree. Some think it will be fine as long as I do the Big 3 upgrade with the stock alternator. What do you think? If I must get a HO alternator what amp are we talking about? If I try to run this system with the stock alternator am I looking at any potential damage issues? I don't want to fire this thing up if that's the case. Let me know if you need any additional information. I appreciate your help!
