chinxtaboi
if i upgrade from a 500 watt amp to a 1000watt amp... do i need to upgrade my wiring???//content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
it depends, if u already have a large enough wire, then no, but if u dont then yes. what gauge are yoou running right now?Originally posted by chinxtaboi if i upgrade from a 500 watt amp to a 1000watt amp... do i need to upgrade my wiring???//content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
upgrade! with alot of factors I dont know right now like wire length and current draw from the amp ect I would say to go with at least 4 gauge ground and 4 gauge power and you should be OK.. but you might as well go with 0/1 gauge. As we all know you will be upgrading again soon. We all do it here.Originally posted by chinxtaboi i think the ground wire is 8 gauge and the wiring to the subs is 12......
wut do i do?
for only $300 yea.. it seems to be worth it.!. be sure you have those Hx2s in the correct box for them. thats the most important thing you can do.Originally posted by chinxtaboi allrighty....thanks
quick question....
upgrade from 2 12" kicker compvrs / memphis 500 watt amp
to 2 12" punch hx2s / ma audio 1000 watt amp (all for $300)
... is it worth the upgrade??
