Do I need new alt or battery??
lionel2
PA
I plan on buying a new sub amp that has a 135A fuse rating and i have a 4 channel that is installed and its a 40A fuse rating amplifier....my 4 channel can only take 8 AWG power and ground...but the 2 channel sub amp can take 4 AWG power and ground...Do I have to do 1 run of 8 AWG for 4 channel...individually fused under the hood with 40A fuse and another run of 4 AWG for sub amp..individually fused under the hood with like a...humm not sure what fuse to use under the hood for sub amp...what size fuse do i use under the hood for 135A fuse rating sub amp?? a 135A fuse if they have em??....I would not need a distro-block with this setup..correct??...with a total of 175A will a yellow top battery and 105A alternator be good enough??...just wondering if I should buy a new yellow top or do I also have to buy a new like 200A alternator...thanks
I would say definitly, Your only going to get the best performance from your equipment when supply adaquete power. I just ordered a 160 amp from Ohio Generator. It was very pricy but They have been around since I started installing in the 90's and have a great rep.
cause i was thinking of getting a US Amps USA-300X..old school...900x1@ 4 ohms...and its 135A fuse rating...but would I be okay with just a yellow top..cause I plan on getting one really soon...as for the alternator....ohio gen is good really good...But who would install the alternator?? Cause its not like its a stock replacement that the dealership is used to...I am sure my local shop can do it...but it dont hurt nothing to put on a bigger...say 200A alternator..just adds more power...i guess i will check out ohio gen web page..if i can find it..thanks
Actually the alternator they have for your car and mine is a stock replacement but with different internals. I just got the call that mine is ready but they are cash only, they will not except debit or check so I have to go down to Ohio to get it.//content.invisioncic.com/y282845/emoticons/furious.gif.fc81ca146dbff91fede3ed290dbc4f4c.gif
All you have to tell them is the make and model and engine size??...do I have to get the OEM part number?? cause i have no idea what it is or where to find it..about how much are there 200A alts??..no chrome just regular..thanks
Just your car, engine. Thats it probably not 200. Mine is 140 at 1800rpm. thats from 75only - stock alt.
lionel2
lionel2
PA
ex_03
