do i need an adapter or can i wire my HU directly to stock wires?
I just plan on hookng up the stock speakers for now no amp or sub I just wanna know if I NEED to go to futur shop and buy the adapter or if i can splice the wires?
x2 buy the harness. for the 6 dollars it's going to cost you it will save you time, and if you ever decide to sell the car you can throw the stock one back in with no problems.
I have a 2006 Honda Odyssey with a 130amp factory alternator. I have done big 3 with ground to chassis and engine ground. I run a 2000watt RMS...
While most Asian and African markets will identify Honda's small hatchback as the Jazz model, most Western regions will know the same model as the...
71
421
328
$$$1smiley5$$$
high climber
$$$1smiley5$$$
toronto
oxsign
    May 12, 2024
Brendon Jenness
    May 11, 2024
