Do I need a line driver?
  • 5
The voltage doesn't matter, but you'll be cutting back from 3 pairs of pre-outs to 2 pairs. Is that going to matter? If you want 4 speakers and a subwoofer all amplified, then yes, it matters.
A line driver doesn't help with that. You still get only 2 pairs. There's no problem splitting RCAs, even at 2V.
The correct answer is yes, you want both left and right so you get low end information from both channels. It is very common for recording...
155
While most Asian and African markets will identify Honda's small hatchback as the Jazz model, most Western regions will know the same model as the...
116
462
BigAl
BigAl
birmingham,al
trumpet
    May 18, 2024
    May 16, 2024
