Do I need a bigger trunk?
  • 2
MakkMar10
Bangin on a Budget
411
SoCal
I have a Jeep Patriot an my trunk dimensions are 38"x23", adjustable hieght but 17" is my window line. Im look'n in to Sound Qubed HDS series, of course i would love the 15's. Thing is, Do i have the space? I believe i can get 5cu after displacement an port....
you could do 2 12s in that space. That's 7.04 gross space before all displacements. Also 1 15 would work. Really up to you
U think i could raise the box height to get the airspace need'd for 15's????
155
While most Asian and African markets will identify Honda's small hatchback as the Jazz model, most Western regions will know the same model as the...
116
462
356
MakkMar10
Bangin on a Budget
MakkMar10
SoCal
MakkMar10
    May 18, 2024
    May 16, 2024
