dmm on subs
Bobby322
Thought my problem was just an amp fuse but now I'm thinking my subs are screwed up. I'm ggetting a dmm (old one broke). When I hook it up, what should it read to indicate wether my subs are good or bad? The coils look fine to me
if he subs r already out of the box test each vc
it will read out the same as what type of vc u have
for instance if u have a dual 2 sub each one will read out around 2
single 4 will read out at 4 or around it
Okay well my subs are 2 x 2 ohm...so if it reads 2 im okay? 0 not good? Do I put it on each set of voice coils?
okay and i should disconnect all wires? Also, is there any way to tell if my amp is putting out power with a dmm?
lick your fingers then put one on the + terminal and one on the - terminal at full tilt with gain maxxed
ps. i never tried this but im sure it will work
Lol I accidentally did that the other day. The wires did not have a good connection on the box wire port. So not thinking i pulled um out and went to re twist the ends. It did not take me long to realize it was a bad idea.
Bobby322
Bobby322
TX
1rockford1
