Sold DLS Ultimate A5 (3 channel) $350 shipped, AC EQX
frkkevin
Trying this again.. $350 shipped. Need this sold. Only trades would be for an 04/05 RE XXX or a DLS A4/A6
* RMS output per channel at 13,8 volts, 20 Hz - 20 kHz ,
* Mode : AB
* Number of channels : 3
* Output power in 4 ohm : 2 x 85 W
* Output power in 2 ohm : 2 x 100 W
* Mono channel, ouput power in 4 ohm : 300 W
* Mono channel, output power in 2 ohm : 500 W
* Mono channel, output power in 1 ohm : 780 W
* S / N ratio, A-weighted : > 100 dB
* Damping factor : > 200
* Input impedance : > 10 kohm
* Input sensitivity, variable : 0,2 - 7 V
* Filter, front channels : Highpass: 50-125 Hz
* Filter, mono channel : Lowpass: 40-90 Hz. Subsonic: 25 Hz
* Phase shift control 0-180 degr. : Yes
* Remote sub level control with phase control : Yes
* Terminal for external cooling fan : Yes
* Dual DC-inputs : No
* Current draw, idle : 0,5 A
* Current draw, maximum : 90 A
* Dimensions W x D x H : 410 x 240 x 73 mm (16,15 x 9,45 x 2,87 inch)
ULTIMATE series A5, a three-channel amplifier rated at 2 x 85 Watts in stereo an 1 x 300 Watts in mono. In two ohm load it delivers 2 x 100 Watts in stereo and 1 x 500 Watts in mono. The mono channel is 1 ohm stable. Built-in fan control. Built-in, variable 50-125 Hz switchable high-pass filter and a 40 - 90 Hz low-pass filter for subwoofers. The sub channel is also equipped with a disconnectable 25 Hz subsonic filter.
The perfect amplifier for a good front system and one or more subwoofers in the trunk. Remote sub level control that includes phase shift control 0-180 degrees.
Audiocontrol EQX for $100 shipped.. bought it off diymobile and never used/tried it.
frkkevin
frkkevin
US
frkkevin
