DIY amp "bench testing"
I hate this forum. I reposted this in my home forum. answered in >10 seconds literally.
But were the answers you got good information or not ????
Post the response you got and I'll pick it apart and tell you how you should really do it if I don't think it's accurate...
If all you have is DMM you could load the amp down with some non-inductive resistors and get a ballpark... really you should have a good clamp meter and someway to make sure you aren't running the amp into distortion...
for a full range amp hook up a piezo tweeter in parallel with the load.. harmonics will make her scream..
Otherwise you need a o-scope or a program like speakerworkshop (and the knoledge to use it)
sweet, in greater than 10 seconds? literally greater than 10 seconds? why, I bet if you ask nice, you might still get an answer in greater then 10 seconds. maybe use the search, or google, and shave a bit off that, get down to less then 10 seconds.
and yes, based on conditions, that method is pretty "ruff". you can overrate the amp by 100% if you try.
You should go eat a d1ck and die. I heard it works.
HAHA //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif:laugh://content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif:laugh://content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif:laugh://content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
x2
germandark
Your order number is 69!
germandark
Tampa, FL
germandark
