distribution question
the rf requires a 150amp fuse, i have a mini 150 on the 4g will be upgrading to a full size fuse/holder for the bigger wire. couldn't find reducers, so i will be leaving about four to 6 inches of the 4g to the amp. will this be ok?
you should be fine with the short run of 4ga. If the only amp you will be using on the 0/1 ga run is the RF, just fuse to 150a right near the battery. If you have another amp, use fusing to suit the system at the battery and fuse the RF amp to 150 on the 4ga feed. No matter what, always fuse near the battery up front.
macsdad
boom-boom
macsdad
Birmingham, Al
macsdad
