Dinosaur amp help
BrockSamson
So i want to use an dinosaur amp (i bought used in like 90's but still works). It is a PSL (Phillips Sound Labs) A75watt 2channel.
How do i find out what the fuse rating should be to install in my car? (google provides little info). No fuses on amp.
I would post a pic but i get errors on mobile.
Not to question your knowledge but (for future reference) how do you determine that rating?
Pulled it straight out of his arse most likely.
Fuses are a LOT cheaper than amp repairs. I'd start at say 15 then move up 5A at a time to 30 if you open it too quickly.
FYI if you never open a fuse when getting really aggressive with the volume knob it will NEVER open quick enough to save the amp in the event of trouble.
BrockSamson
BrockSamson
Earth2
hispls
