Digital vs analog
LMS
NY
I have always used analog eq's(audiocontrol and ppi's 1/3 octave eq's )
and I am considering switching to the alpine h701 or audioocontrol DQXS. Going digital will certainly reduce the number of processors in the signal chain.(cleaner sound)
Can anyone explain which is the preferred type(digital or analog) for an SQ instal?
I have always used analog eq's(audiocontrol and ppi's 1/3 octave eq's ) and I am considering switching to the alpine h701 or audioocontrol DQXS. Going digital will certainly reduce the number of processors in the signal chain.(cleaner sound)
same shit digital is prolly a tad bit more efficient and a bit more on target as far as sound goes
heat and humidity can bother anolog components . throws them out of whack and need to readjust to achieve the end result you originally set the anolog processors for. digital is more precise and once you set it forget it...all you have to do is do your presets for your listening habbits.
LMS
LMS
NY
audiolife
