digital designs m3a
cal
M3a Features
The M3a has been our most popular high powered amp for many years. The M3 was never designed for spec power, but was one of the first amps in this power range to utilize a high capacity quad power supply and rock solid output section. The M3a continues the tradition delivering over 3000 Watts of long term, SQ quality, RMS power at alternator charging levels. The M3a has been the go-to amp of choice for high performance sub systems. Specifications Input Sensitivity 0.15V - 5V Variable High Pass Filter Variable Low Pass Filter 20Hz - 200Hz @ 24dB/Oct Variable Sub-sonic Filter 10Hz - 50Hz @ 24dB/Oct Variable Bass Boost 0-6dB @ 45Hz Tested Voltage 12v -14v Tested THD ≥1% damping Factor Signal to Noise >100dB Channels 1 Cont Power at 1 ohm 2200W x 1 @ 12v Cont Power at 2 ohm Cont Power at 4 ohm Bridged Dynamic Power 4000W x 1ch Efficiency thru Output Dimensions - mm 546.1L x 232W x 63.5H Dimensions - inches 21.5L x 9.13W x 2.5L Shipping Weight 21 lbs
USED IT WORKS PERFECT NEVER HAD ISSUES . THERE ARE A FEW TINY IMPERFECTIONS ON THE CASE LOOK LIKE ROCK CHIPS I TOOK THE TIP OD BLACK MARKER AND YOU CANT EVEN SEE THEM DONT EVEN COME OUT IN PICS IM JUST REAL PICKEY AND SEE EVERY THING THE WORST IS ON THE BOTTOM PLATE LOOK LIKE LITE RUB MARKS IM GUSSEING FROM SHIPPING THE AMP WAS NOT IN PLASTIC BAG I HAVE ORIGINAL BOX ITS NOT THE BEST SHAPE BUT I GOT IT. REMOTE GAIN AND CABLE ARE INCLUDED CABLE IS NOT IN PICS BUT WILL BE SHIPPED WITH AMP.IM SELLING THIS BECAUSE MY BUILD FELL THRU AND AM NOT SURE WHAT I WILL DO NEXT.
550 SHIPPED CON US ONLY. NO TRADES NEED CASH .
SHIPPING IS INCLUDEDD IN PRICE AND I ONLY ACCEPT PAYPAL .
I HAVE NO REFRENCES HERE BUT I GOT PLENTY ON CACO UNDER CALORIU
MY AMP IS LISTED THER UNDER MONO SECTION DDM3A
FOR SOME REASON I DONT GET EMAIL NOTIFICATION SO IF I DONT REPLY PLEASE CALL OR TEXT ME 312-772-0000
I WILL TRY TO CHECK MY P.M. AND THIS THRAED A FEW TIMES A DAY.
cal
cal
cal
