Digital designs german mids
cal
ddaudio ddaw6.5
BL 5.55
CMS 0.33mm/N
Frequency Response 50Hz - 14kHz
FS 66.01 Hz
Magnet Weight 12 oz
Moving Mass 17.48g
Nominal Impedance 4 Ohm
Power Handling 120/480 W RMS
QES 0.85
QTS 0.68
QMS 4.36
SPL 1W, 1m 90.5dB
Suspension Travel 25mm
VAS 8.0 l
Voice Coil Diameter 37mm
Woofer Diameter 6.5" 165mm
nib never used or mounted. was going to used these with a set of ddw6.5 midbass drivers but plans have changed . includes are grills and mounting hardware.
180 shipped
and trades i will accept are crescendo ft1 tweters plus cash or dd b2 tweeters plus cash. no other trades accepted .
refrences http://www.caraudio.com/forums/member.php?u=1006316
if somebody is intrested i can add a set of oldschool compatiton crossover's and 1 set of american bass sq tweeters for 245 shipped. you get a wicked set of comps .tweeters are new crossover are barely used
open to partial trade crescendo ft1 tweeters or dd b2 tweeters plus cash . no other trades .
I used to have a pair of dd audio redline 608s, for eight inch subs they were very impressive, at least until that ole upgrade bug bit anyway. I...
4K
I use K3b to rip cds and for converting to any file extension I use Sound Converter or Soundkonverter on a Linux machine but you should be able to...
15
946
That makes sense. I took it apart today. It doesn't look too impressive but it should be better than the head unit. I'm going to install something...
cal
cal
cal
    May 24, 2024
