Digital designs german mids
cal
ddaudio ddaw6.5
BL 5.55
CMS 0.33mm/N
Frequency Response 50Hz - 14kHz
FS 66.01 Hz
Magnet Weight 12 oz
Moving Mass 17.48g
Nominal Impedance 4 Ohm
Power Handling 120/480 W RMS
QES 0.85
QTS 0.68
QMS 4.36
SPL 1W, 1m 90.5dB
Suspension Travel 25mm
VAS 8.0 l
Voice Coil Diameter 37mm
Woofer Diameter 6.5" 165mm
nib never used or mounted. was going to used these with a set of ddw6.5 midbass drivers but plans have changed . includes are grills and mounting hardware.
180 shipped
and trades i will accept are crescendo ft1 tweters plus cash or dd b2 tweeters plus cash. no other trades accepted .
refrences http://www.caraudio.com/forums/member.php?u=1006316
if somebody is intrested i can add a set of oldschool compatiton crossover's and 1 set of american bass sq tweeters for 245 shipped. you get a wicked set of comps .tweeters are new crossover are barely used
open to partial trade crescendo ft1 tweeters or dd b2 tweeters plus cash . no other trades .
I used to have a pair of dd audio redline 608s, for eight inch subs they were very impressive, at least until that ole upgrade bug bit anyway. I...
4K
I use K3b to rip cds and for converting to any file extension I use Sound Converter or Soundkonverter on a Linux machine but you should be able to...
15
730
That makes sense. I took it apart today. It doesn't look too impressive but it should be better than the head unit. I'm going to install something...
cal
cal
cal
    May 18, 2024
    May 16, 2024
