wildcat
Thinking about getting this to power my 2 pr 12s.. here are the specs:
BRIDGED 1000 X 1
CHANNELS 1
CONT POWER AT 1 OHM 1000 X 1
CONT POWER AT 2 OHM NA
CONT POWER AT 4 OHM NA
DAMPING FACTOR >100
DIMENSIONS (INCHES) 2.08 X 9.45 X 15
DIMENSIONS (METRIC) 53 X 240 X 380
DYNAMIC POWER 2000W
EFFICIENCY THRU OUTPUT 65%
INPUT SENSITIVITY 0.2V - 6V
SHIPPING WEIGHT 11 LBS
S/N RATIO >95DB
TESTED THD 0.05%
TESTED VOLTAGE 13.8V
VARIABLE BASS BOOST 0 - 12DB @ 45 HZ
VARIABLE HIGH PASS FILTER 20HZ - 50HZ @ 12DB/OCT
VARIABLE LOW PASS FILTER 50HZ - 250 HZ @12DB/OCT
Will it be worth it?
BRIDGED 1000 X 1
CHANNELS 1
DAMPING FACTOR >100
DYNAMIC POWER 2000W
S/N RATIO >95DB
TESTED THD 0.05%
