Digital Audio Output
i belive that whould be more expensive since it would need a more powerfull processor.
the deck already has a DAC for the preamp after which it goes to either internal amp or to external..
the 2 options for digital are coaxial digital and optical digital.
coaxial digital is similar to RCA cable and will also pick up noise and has other limitations
optical digital cannot be bent past certain angle.
and of course the licensing and other corporate BS
then there is a thing called consumer research that tells companies that this certain idea will not make any money so DONT DO IT...
so in this case after few attempts to show off and "be the first one to introduce" the companies backoff and wait untill it goes mainstream so they can say look here back in the day... look what i can do...
alpine made a 5 channel optical amp
and they still make optical output on their indash monitors
my guess the problem would be is everyone tries to push their own standard
home audio usually gets their sht straight alot quicker than car audio why i dont know especially is they are made by same company...
pioneer makes a cd player with optical outputs and amps to go with it
mercedes makes the optical audio (harmann/something) that are pain in the *** to work around.
but the amp is tiny.
the amp is the size of a harddrive with a big heatsink mounted on it powers 9 speakers + subwoofer. pretty **** good.
plus its not very fun to work with optical cables
can you imagine how much it would cost you to install a 4 channel amp and to run an optical cable? with all the moving parts and bends in the car.
that would mean stripping the whole interior and laying the cable down tightly secured to make sure it doesnt move or get squiched or pulled... a big major pain...
stripping them biitches down is the fun part //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
and a major part of the install EXPENSE, which is why most people daon't want to do it.
But the DRZ uses a proprietary optical out, I am still trying to utilize it with the Bitones. //content.invisioncic.com/y282845/emoticons/mad.gif.c18f003ab0ef8a0d9c27ca78d77a6392.gif
tb30570
tb30570
North Dakota
raverx3m
