Diffrence in HO Alts.
im going to be using a HK4000D, hc2400 in the trunk and possibly and hc14 or 1800 under the hood....i called both places to find all the diffrences
the 200AMP alt will do 105 charging at idle
the 250 alt will do 140 and has a pulley to optimize idle.
thanks
Ok so im still trying to figure out is this going to be worth it
the 250 actually only puts out 120 at idle and cost $170 more...Im going to be doing two runs of 1/0 to a 9a31 and a hc1400 up front. Should i spend the extra 170 for 15 extra amps at idle and 50 at 1200-1500 rpm?? I dont think its worth it...im going to have the gains set at around 2500-2700rms if it will even push that out...
BreakDaLaw
Cavalier Killer!
BreakDaLaw
Altavista
BreakDaLaw
michigan born
    May 14, 2026
michigan born
    May 14, 2026
