XtrmAudioCncpts 10+ year member CarAudio.com Veteran 4,399 84 Fairfax, Va Jun 2, 2005 #1 what would the load be if i had a 2 ohm dvc sub and a 4 ohm dvc sub. what could my loads be with all possible set ups Click to read more...
J jsloan10 10+ year member Registered User 996 1 anywhere Jun 2, 2005 #2 You cannot use those subs together off the same amp, well you technically could but it wouldnt perform the way you want it to. Electricity takes the path of least resistance so the sub wired for a lower load will get more power than the other. By themselves you have the options of- DVC 2OHM- 1 or 4ohms DVC 4ohm- 2 or 8ohms
OP XtrmAudioCncpts 10+ year member CarAudio.com Veteran 4,399 84 Fairfax, Va Jun 3, 2005 Thread Starter #3 i know what they are by themselves i was wanting to know what they would be together but i know the answer to my question
