Difference between 4 and 2 ohm
The higher the ohms, the less power it will draw from your amp.
If your amp is 1 ohm stable and 1000 watts, the 4 ohm speaker will only run around 250 watts, 2 ohm sub will be around 500, 1 ohm will recieve the full 1000.
It is a lot more complex than this, but this is the general idea.
I'm tired of typing
Think of ohms as the thickness of a hose.
A big number means a smaller hose.
A small hose will not let a lot of water (watts) through it.
A big hose will offer the least resistance to flow.
OHM = resistance
cause i think both mine are 4 ohm and i got a 1000 zx running to each one turned all the way up and i feel i should b gettin more fom the amps
You could be getting the same amount of power from them both being hooked up to the same amp, the second amp was wasted $$ //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
unless they are dual 4 coils and he forgot to tell us that
SPL-Roberts
SPL-Roberts
M-Town
PaulThompson229
