Difference between 4 and 2 ohm
i got 0 gauge wire yellow top battery...ported box but it is to small it is way under sized would that make that much difference
Yes, the box makes a HUGE difference, those subs should be getting at least 3.5-4 ft^3 each, build yourself a box and your problems will be solved
ya i figured the subs didnt have enough breathing room but didnt no it hurt it that much cause homie i tryin to bumpin hard and u guy have any good ideas on 6.5 that i could get for my durango cause i was leanin towards memphis msq's
cause i think both mine are 4 ohm and i got a 1000 zx running to each one turned all the way up and i feel i should b gettin more fom the amps
wire your subs down to 2 ohm, strap your amps and you u will see a difference.
What have you done as far as electrical?
ya but i dont like it....i want to get rid of these amps and find a 3000 watt amp for both them then just keep two or say **** it and get 2 more so i have four
These are the ones I have, except I have the 3-ways and they are amazing
http://woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=1110
These are the absolute top of the line ones
http://woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=5616
But these will do nicely if you wanna save some $$
http://woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=5023
All this assuming you wanna do 2 way and not 3 way, also what kind of amp do you have to run the comps?
Im telling you, those amps are perfect for those subs, your box is your problem, and the ZX-2500 won't be able to run your subs because with 2 D4 subs you get a final load of 1 ohm and the 2500 isn't stable there and will go into protect
SPL-Roberts
SPL-Roberts
M-Town
PaulThompson229
