Sold Diamond Audio / Alpine / MTX / Sherwood
02Corvette
LS1-1320 feet at a time
Alpine Type X 6.5" components
-$200 shipped OBO
-Brand New In Box/never installed
-spx-177r
-6.5" mid
-tweeter
-cross over
DIAMOND AUDIO D361i 6-1/2" D3 COAXIAL
$50 shipped OBO
(1 coaxil has a small dent in the tweeter, still works)
Speaker Type: Full Range
Large Diameter: 6.5"
Small Diameter: 1"
Mounting Depth: 2.5"
Tweeter Mounting Type: Angle
Sensitivity: 91
Frequency Response: 54-20
RMS/Max: 60/120 Watts
Sherwood A100X4 amp
-$80 plus shipping
-4X100rms @ 4ohms
-2X250rms @4ohms
I currently do not have pics, this is one like it w/ info:
http://www.wwwsales.net/amps/sherwood_a_100x4.htm
MTX blue thunder PRO 752
$50 shipped
Specifications:
RMS Power measured at 12.5 Volts DC:
37.5 watts x 2 into a 4 ohm load with less than 0.05% THD+N
75 watts x 2 into a 2 ohm load with less than 0.1% THD+N
150 watts bridged into a 4 ohm load with less than 0.1% THD+N
Dynamic Power (IHF-202 standard) measured at 14.4 Volts DC:
90 watts x 2 into a 4 ohm load
165 watts x 2 into a 2 ohm load
325 watts bridged into a 4 ohm load
Signal to Noise Ratio
> or = 110dB A-Weighted
Damping Factor:
>200
Maximum Input
8 Vrms
Frequency Response
20Hz-20kHz ±0.25dB
Bass EQ
(0-18dB) centered at 45Hz
Crossover
Variable 40Hz to 175Hz
12-18dB/Octave
HP or LP configurable
Dimensions
8" x 9" x 2" (20.3cm x 22.8cm x 5cm)
9-1/4 Wide Including IsoFeet (23.5cm)
MORE INFO AT:
http://www.mtx.com/caraudio/archive/pro75x2.cfm
Phoenix Gold 2-way electronic cross over
-$40 OBO
- AX-204
Bandpass box for 2 10" subs
-$40 OBO local pickup only 77802
MY CELL # 979-324-2260
02Corvette
02Corvette
Houston, TX
PRIVATEpastry
