Sold diamond audio\alpine cva 1004
iowaaurora
2 diamond audio d5 1200.1 220.00 plus shipping and pp fees each
only 1 of the following 4 sale whitch ever one shows intrest first
1 diamond audio d5 600.4 220.00 plus shipping and pp fees
1 diamond audio d5 600.2 220.00 plus shipping and pp fees
alpine cva 1004 6 disk cd changer
exp. box kce 104v
325.00 plus shipping and pp fees
2 soundstreaM RFW 10" D4 60 plus shipping and pp fees each
I ALSO HAVE 1 re sx 18" bnib has not even been takeing out to look at since i bought a pair from team h&k 265 plus shipping and pp fees
pics
specs on d5 1200.1
FEATURES
Technical
• Fully Regulated Power Supply
• Up To 5V RMS Input Signal Voltage Capability
• Low pass x-over 24 dB/oct. 50 Hz-250 Hz
• On Board Sub-sonic Filter 12 dB/oct. 15 Hz-40 Hz
• RCA Outputs
• 2 oz. Silver Plated Copper Circuit Board
• Massive Proprietary Heatsink
Convenience/Appearance
• Fully Variable Electronic Crossovers
• Nickel Plated Solid Brass, Circuit Board Mounted, 4 Gauge Direct
Power/Ground Connector Blocks
• Nickel Plated Solid Brass, Circuit Board Mounted, 10 Gauge Direct or
Banana Plug Direct Speaker Connectors
• Fly Cut Billet Aluminum End Plates
• Fully Adjustable Mounting Feet
SPECIFICATIONS
Frequency Response: 10 – 500 Hz
Signal-to-Noise Ratio: 80dB
THD: 0.10%
Input Sensitivity: .2 to 5V RMS
Input Impedance: >20k Ohms
Power Supply Operating Range: 11 to 14.5V DC
1 Diamond Audio Technology
DIMENSIONS
D5 1200.1
Length: 12 1/2" Length: 14 1/2"
Width: 12" Width: 12"
Height: 2 3/4" Height: 2 3/4"
CONTINUOUS RMS OUTPUT POWER
Note: Full Rated Power is generated at all voltages between 11 and 14.5V DC D5 1200.1
600W x 1 @ 2 Ohm 1200W x 1 @ 1 Ohm
(minimum impedance) (minimum impedance)
CROSSOVER SPECIFICATIONS
Quantity: 1
Type: Fully Independent and Adjustable Lowpass and Subsonic
Slope: 12 dB/Octave Sub-sonic, 24 dB/Octave Lowpass
Alignment: Butterworth
iowaaurora
iowaaurora
des moines iowa
iowaaurora
michigan born
    May 14, 2026
michigan born
    May 14, 2026
