Central Region DFW USACI and DB Drag myspace
IA,IL,IN,KS,MI,MO,MN,NE,OH,OK,TX,WI
Everyone needs to be there at 10am. We place you in the correct class then you do a qualifying run. You are then placed in a bracket where the top 8 vehicles are placed in this bracket for the certain class. The computer will select who you will go up against in a side by side action. Highest score moves on to the next round till a bracket champion is left. You must qualify before you can run in the brackets. It will televised live on you tube and DB Drag Racing TV via the internet. Bass Race uses the same type of qualify and bracket type of fun. We take the best scores and select the top 8 to go up against each other 1 on 1 till a champion emerges.
So we have the burp classes and Bass Race.
Base race breaks down like so
119.9-play music for 30 seconds without going over the 119.9 number.
129.9- play music for 30 seconds without going over 129.9 number
139.9- play music for 30 seconds without going over 139.9 number
149.9- play music for 30 seconds without going over 149.9 number
159.9- play music for 30 seconds without going over 159.9 number
1st place trophy is 3ft tall
2nd and 3rd ar about 15" tall.
Depending on the turn out, I have cups for the highest SPL and Perfect score in Bass Race.
so its divided by cone size i read the doors have to be closed can the engine run or is this with the motor off. also its the top eight cars in each class what happpens if there only one guy in a certain class
Divided by cone area-yes
Door closed- yes
engine off- some classes
if there are less then eight the computer will sort out the 1 on 1 stuff
If there is only one in that class-then he wins.
Dfw Bass Asked If You Was Banned From Southern Bass Forms. And If You Signed Up Or Was Banned From It? Its Because, Its A Members Only Form. Not Trying To Start Shyt Mel. Just Answering A Tread.
Oh, ok.
Divided by cone area-yesDoor closed- yes
so there's different rules concidering the cone size or the amont of power your running what about the battery limit is there rule for that
http://www.dbdrag.com/dbdrag/rules/2009/rules.asp?Org_ID=1&season=2009&section=2
This section contains basic information regarding competitor classification based on the equipment installed in the contestant's vehicle. For specific limitations regarding vehicle modifications for each division, refer to Sections 3-6 later in this rulebook. For a quick overview of each class please refer to the dB Drag Racing Class Matrix.
The standard classes for dB Drag Racing are as follows...
Street Stock Division
The Street Stock class is intended for normal, after market auto sound systems. The equipment permitted in these classes is restricted to the "consumer-grade" components that are sold everyday at auto sound retail establishments. Veteran contestants, competition teams, and "hardcore" competitors are encouraged to compete in one of our other divisions.
Only consumer grade components may be used.
Any number of amplifiers may be used. However, the maximum total RMS power in the system must be 2000 watts or less.
Woofers with cast frame baskets are prohibited.
The maximum voice coil diameter is 2.5 inches.
Vans, CRX's, Panda's (or Panda derivatives), and commercial vehicles are prohibited from competing in the Street Stock Division.
Contestants must play music when competing. Test tones (or songs containing test tones) are prohibited.
Street Stock Division - 2000 Watts maximum total RMS power. A maximum of 4 conductors may be attached to each woofer. (Please see the definitions section for more detail regarding conductors.)
One 15-inch woofer
OR a maximum of two 12-inch woofers
OR a maximum of three 10-inch woofers
OR a maximum of four 8-inch woofers
Street Division
The Street classes are intended as a migration path for more advanced contestants. The rules in this division are stricter than those found in the Street Stock division and a greater variety of products (including "competition-grade" components) may be used.
Cargo vans and commercial vehicles are prohibited from competing in the Street Division.
Street A Class - A maximum of 1 subwoofer amplifier may be used. A maximum TOTAL of 2 electrical conductors may be used to connect the amplifier to the woofer(s). (Please see the definitions section for more detail regarding conductors.)
One 12-inch woofer
OR a maximum of two 10-inch woofers
OR a maximum of three 8-inch woofers
Street B Class - A maximum of 1 subwoofer amplifiers (or 2 externally bridged monoblock amplifiers) may be used. A maximum TOTAL of 2 electrical conductors may be used to connect the amplifier(s) to the woofer(s).
One 15-inch woofer
Street C Class - A maximum of 2 subwoofer amplifiers (or 4 externally bridged monoblock amplifiers) may be used. A maximum TOTAL of 4 electrical conductors may be used to connect the amplifier(s) to the woofer(s).
One 18-inch woofer
OR a maximum of two 15-inch woofers
OR a maximum of four 12-inch woofers
OR a maximum of six 10-inch woofers
OR a maximum of eight 8-inch woofers
Additional Guidelines for the Street Division:
Amplifiers used for non-subwoofer applications will not be counted.
Amplifiers that are constructed in such a way as to circumvent the amp quantity limitation may be prohibited from use in this division or may count as multiple amplifiers. (Please see Section 14 for more information on amplification.)
Street Max Division
The Street Max class retains the "normal use" restrictions associated with the Street division while allowing the contestant to utilize a "wall" in his or her installation.
Street Max Class - 1-4 Woofers. A maximum of 2 subwoofer amplifiers (or 4 externally bridged monoblock amplifiers) may be used. A maximum TOTAL of 4 electrical conductors may be used to connect the amplifier(s) to the woofer(s).
Additional Guidelines for the Street Max Division:
Super Street NW Division
The Super Street NW class is designed for those contestants wishing to maximize the equipment in their installs without building a wall or moving into the Super Street or Extreme divisions.
Super Street NW Class - 1+ Woofers. A maximum of 4 subwoofer amplifiers (or 8 externally bridged monoblock amplifiers) may be used. A maximum TOTAL of 8 electrical conductors may be used to connect the amplifier(s) to the woofer(s). A maximum of 4 conductors may be attached to each woofer
Additional Guidelines for the Super Street NW Class:
Super Street Division
The Super Street classes are designed for contestants wishing to maximize the equipment in their vehicles without making the structural modifications required for the Extreme division. It is not uncommon to find "veteran", "hardcore" contestants participating in these classes. "Competition-grade" components are normally used for Super Street.
Super Street 1-2 Class - 1-2 Woofers. A maximum of 4 conductors may be attached to each woofer
Super Street 3-4 Class - 3-4 Woofers. A maximum of 4 conductors may be attached to each woofer
Super Street 5+ Class - 5+ Woofers. A maximum of 4 conductors may be attached to each woofer
Extreme Division
The Extreme classes are intended for contestants wishing to take their systems to the very limits of technology and beyond. Typically, only the most veteran contestants participate in these classes on a professional level.
Extreme 1 Class - 1 Woofer. A maximum of 4 conductors may be attached to each woofer
Extreme 2+ Class - 2+ Woofers. A maximum of 4 conductors may be attached to each woofer
Optional Classes
The following classes are not offered at the World Finals.
Freestyle - This class is intended for "first-time" contestants only. Typically, there are no rules in this class except that once you win, you must move up into one of the standard classes listed above.
Monster - This class is intended as an "exhibition" class only.
We will also have someone at the show who will place you in the correct bracket. We will also let you know where you can fit in, in a 2nd class if you choose.
I will have another 4 mics at the next event to do...DEATH MATCH.
3mins of playing music, last one standing wins. I was watchen Scottie Johnson's Death Match run and it kicks ***.
One 15-inch woofer
Street Division
One 12-inch woofer
One 15-inch woofer
One 18-inch woofer
Street Max Division
Extreme Division
Optional Classes
Looking over what you posted and knowing the problems you getting ready to run in to what made you decided to direct shows for both usaci & db drag. The local competitors for this area are more set up for my events & usaci none of this makes no sense
The Bass Race events are the real fun ones. This is where the money really does not make that much of a diffrence. The Bass Race is what go me to start doing the Db Drag events. Lets say you have 8 15" subs and 40K in power. You can run any class you want in Bass Race but the tough part is being able to control the perfect score number without going over. Thats the part where you need to know your system really well.
RXZILLA
Resurrection of a legend…
RXZILLA
Texas
james122527
