Determining Port Area
kraudio12
Alright i was wondering if there a equation or a given rule to determining the port area for a ported box
because i have seen people use really big ports and some using really small ports
if there is a way to determine the correct port area with a possible relation to the the speakers xmax
thanks for any help recieved
port area is generally 16 cu. in. per cu. ft. of air space. You probably see smaller ports on smaller boxes and port area is just width x height so you can have a skinny but tall port or a smaller square port. If you go too small you'll get port noise, I've had that and it is very unpleasent.
okay so there is really no relation between xmax and port area because for every box i have made i used somewhere between 12 to 18 i believe depending on the size of the sub
because im making a box for a 10 and i plan on using 12 sq for a 1 cubic box tuned to 36hz
It really depends on the amount of power you plan to use also. Some fantastic home speakers use very small ports in large boxes. It works because you have low power, low x-max
Port turbulence has to do with velocity of air in the port. The more air you're trying to move in it the more you're likely to run into port noise.
All that being said, it seems to be the conventional wisdom (backed up to a large degree by measurable repeatable results) that large ports are louder. The tradeoff of course is the length will often becom impractical particularly in small boxes with low tuning.
I use 12-14in^2 per ft^3, normally closer to 12...I tune too low to go any bigger. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Never had port noise issues either.
kraudio12
kraudio12
CP, Indiana
RAM_Designs
