Designing a remote starter
CarAudioAddict
What did I do now?
okay here's the scoop.
I am designing a remote starter to run off the trunk pop option of my alarm.
I need to know if there is a wire in a 1985 GM vehicle that changes state when the engine has started and is running.
By changes state I mean goes:
from ground to NC
from NC to ground
from Hot to NC
from NC to Hot
from ground to hot (preferred)
so I'm guessing no-one knows much about GM electrical Systems.
Would grounding a Relay through the voltage regulator damage it?
I have discovered that my alternator has a wire that changes from ground to hot when the engine starts, the problem is - this wire is controlled by the voltage regulator inside the alt.
CarAudioAddict
What did I do now?
CarAudioAddict
Alberta
CarAudioAddict
Doxquzme
    Jun 18, 2026
Doxquzme
    Jun 18, 2026
