design for 4th order bandpass needed
91caprice
i need a design for a 4th order bandpass for a pair of Addictive Audio 12s. Ill be pushing them with an Addictive Audio 50.1 amp (500rms at 1ohm). also i dont have a problem paying for a design.
this is going in a 2dr s10 blazer. im not chasing numbers,i just want a nice ground pounder.
max dimensions i have to work with 38"w X 15"h X 50"d .
sub T/S
aa12v1
OD = 12.519"
ID = 11.181"
MD = 5.905"
Displacement:
0.146 cu.ft.
-Mechanical Parameters-parallel
FS 33.22Hz
Qms 4.173
Vas 50.22liters
Cms 0.135mm/N
Mms 171.1g
Rms 8.505kg/s
Xmax 12.0mm
P-dia 255mm
Sd 0.0511sq.m
P-Vd 0.613liters
-Electrical Parameters-
Qes 0.674
Re 1.6ohms
Le 1.17mH
Z 2.0 ohms
Bl 9.168Tm
-Electromech. Parameters-
Qts 0.581
no 0.263%
1-W SPL 87.10db
2.83-V SPL 93.64db
Efficiency Bandwith Product 43hz
Sealed 1.5cuft
ported 2.37cuft (Fb 36.82hz, F3 32.77hz)
square por 14sqin X 10"d
round port 4"dia X 8.75"d
Why do you want a fourth order box in the blazer? You could do a huge slot port box tuned around 35+ and it would slam the shit out of the blazer. Hell, even a sealed box would slam hard. I had a sealed box with two pyle drivers back in 92 and My buddy put them in his blazer for a night of cruising and that shit slammed hard yo. If I was you, I would not do fourth in the blazer....
Car Audio Subwoofer Enclosures Fourth Order/Bass Reflex and Bandpass
Subwoofer Enclosure Calculators, Fraction to Decimal, Parallel, Series, Port Length and Volume Calculators
RE Enclosure Calculator
91caprice
91caprice
Livignston,CA
91caprice
