SOLD denon dct r1 head unit the ultimate sq
psychoacoustics
hammer and the evil one
3,468
Buffalo NY
this unit is an import from japan it has been recently serviced and the cd transport has been replaced
it is tested and works perfect
one small knick on the face
all lights work had amber and green illuminaton
comes with the converter to get usa radio stations and wiring
no manual or box sorry the manual is avaliable but its not really needed
this is the ultimate in purity no xovers or bs just a rotary volume knob no zipper noise from digital
bass trable clock skip forward and back play pause and eject
has rca level inputs with adjustable lever to match radio and cd level
i have a small mp3 player hooked up to min in my daily driver and it works great
$300 shipped
didnt you buy the alpine for the xovers and imprint stuff?
active xovers are so easy to tune so its nice to have a deck or amp that takes care of this especially if you mix and match mids and highs
this dont have any dsp just bass and treble and volume (digital signal processing)
running 2 dsp's sounds like trouble
i bought the alpine 9887 the inprint box a changer and set the system up however it was alwalys giving me trouble i could run the imprint 30 times and get diff results every time
it gives you a few options but they didnt apply to me its setup for a 4 door/4 seater if i remember and i was running a crx with horns and that damm zipper noise drover me nuts every time i changed the volume
114
528
There are a couple of options. You can use a marine bt unit. They come in the size of a hockey puck and can mount anywhere. This is the marine unit.
628
There are bluetooth amplifiers. You can just use your phone or an I Pod as the music source and not touch the radio.
759
psychoacoustics
psychoacoustics
Buffalo NY
psychoacoustics
    May 16, 2024
    May 16, 2024
