Deka Intimidator Batteries?
crfrider
A yes are these batteries good? I am planning on buying 2, I hope it would be enough but First i Have a Kicker ZX2500.1 which has a 300 amp fuse, and a Rockford Fosgate punch 450.2, which has a 50 amp fuse, and a kicker zx150.2 which has a 25 amp fuse, ok I am thinking of buying 1 Deka Intimidator 9A31 for the back battery, now im not sure about how good these batteries are but what are the Amp Hours of this battery, also do they compare to the Kientik 2400? also I will buy a smaller DEKa for the front battery like a Deka Intimidator 9A78 for the front battery? Would these two be enough to power my system, till i can afford a H/O altenator, I would just run my stock 105 amp altenator also I have 1/0 gauge wire and big 3 done in 1/0? any info? thanks
i have two in my trunk they are some nice bats and i believe they are 105? ah. but i would say maybe try to get two for in the back and the upfront one as well because you may see a decent drop with just your stock 105 amp alt. i ran about 3k on one intimidator and a 105 amp alt and i dipped to 12 and high 11s occasionally especially when not taching high
Ya they are nice batts, but like said before I would be careful with just a stock alt. Id just buy one for up front one for the back then get an alt asap and if that isnt quite enough get one more batt in the back.
You'll need more than 1 run of 1/0 if you plan on using 300+ amps.
Run 2 1/0 for positive, and 1 1/0 for ground along with chassis ground.
crfrider
crfrider
Oklahoma
smoka
