deka 9a31 vs hc2400 vs ?
You'll need more than a single group 31 battery to run 3kW //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
if the rest of your electrical is stock... yes... if not, then no
i'm runnin 3K off of my Deka just fine :) took care of alllll of my dimming problems!
between the 2 Deka gets my vote... Brock Jones from Team Hazardous Sounds did a test between the exact 2 batteries and the Deka's were better and the Kinetik didn't even put out what was rated.
Also a single g31 will run 3k fine if you have a ho alt and a similar battery under hood
Deka's are great batteries but I also heard the kinetic batteries dont do rated power.. Powermaster is a great choice also... Stinger SPV70's are also a great choice for the PRICE.... May need two of them though
well i was going to get a 200 amp alt so im set on that and i want to run a single battery if i could so which will last llonger and be better for my application
I love my PowerMaster D3100 //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Between the D3100, a D1200 up front, and stock alt, No dimming with my Sundown 3K at 1 or 1/2 ohm. At 1ohm voltage stayed at above 12 for more then a minute on a tone at full tilt. Haven't done too much testing with it now at .5 ohm, but no dimming or protecting so it isn't dropping too much more.
Deka FTW!
If you bought the kinetik, you'd be buying it just because it was a kinetik. The deka will give you everything the kinetik would and more for a better price.
Yeah the deka's are nice, I just thing they are some ugly batts. //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif. Doesn't really matter as long as you can hide them. Batts in spare tire well ftw, except mine doesn't fit big batts so that's not an option for me. I'll stick with PowerMaster from now on most likely, very nice batts, but very expensive too...
Price:performance, I'd definitely go with Deka, NSB, or those C&D batts that are always on here //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
how big is your stock alt in your mazda i think i am going with 2 dekas in the rear with stock up front for now until i can get an better one i think that it will be alright
Deka FTW!
X2
I use them in mine and in friends systems as well. This guy even made the switch from Kinetik to Deka and said, "his voltage was a lot more stable at full tilt".
X2I use them in mine and in friends systems as well. This guy even made the switch from Kinetik to Deka and said, "his voltage was a lot more stable at full tilt".
he my buddys build is almost done we have some shit to do tommorow but it should bepreety coll dont know if he is posting it on paps websit or not but he is meangreen on there hes doing the 4 18" wmd2s
It's in my sig, 90A stock //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
jdmferio13
feayfm
jdmferio13
Central,PA
ganggreen
vegang
vegang
