Deck Speakers Cutting In n Out
Baby Tex
Ok...not sure if this has been addressed in a previous thread, but I'm working on my girlfriend's stereo (Isn't it always hers that screws up?) and I can't get the speakers that are powered by the deck to work. The deck is a lower model Sony (I told her to buy Pioneer, but whatcher gonna do) and only a year or two old. What happens is that when you're driving down the road, the speakers cut in and out, when you hit bumps and whatnot...hit one bump they go out, the next they come back on...if you slam the passenger door it sometimes works to get them working again. Anyways, I tore the dash apart and tried putting a test light to the speaker leads at the back of the deck to see if any voltage was going to them...After that 1/2 explanation, my question is: If the speaker wires are shorted out somewhere from the deck to the speaker itself, would voltage still be being sent down through the leads? Or would the deck shut them off for safety? Any help would be GREATLY appreciated cause I'm hitting a brick wall with this one...//content.invisioncic.com/y282845/emoticons/banghead.gif.8606515f668c74f6de0281deb475b6fd.gif
Thanks
I doubt that Sony deck has ground fault protection. If you check for voltage at the HU that will only tell you if the output signal is lost. You could try contacting Sony if you want to make sure about the protection. If slamming the passenger door can turn the speakers on and off then either the force of the door is causing a loose or short to shake, or there is a short at the passenger door. Have you checked the speaker connection itself? Have you checked the wiring harness connections? You could try tracing the speaker wire from the deck to the back or bypass the stock speaker wire with a new wire. A loose connection in the back of the deck or at the speaker is usually the problem.
Ok, I fixed it...thank you thank you thank you. Somehow the wires from the rear right speaker were sitting on the metal body and were shorting out the whole worx, how that happened...? But thanx for helping me dude
Baby Tex
Baby Tex
Alberta Canada
Baby Tex
RobGMN
    Jun 8, 2026
DEH-P7700MP.mp4
lbn.wrks
    Jun 8, 2026
