Deck + Amp Problems
insaini
When i turn the volume up on my deck to about a little less then half way ... my deck and amp both keep turning on and off untill i put the volume back down. What could be causing this? ... i changed the amp ... still the same problem ...
I have a
JVC KD-SH77 Deck
Clarion DPX1001.2 AMP
and 2 Rockford Fosgate P212S4 SUBS
anyone know what the problem could be?
here are the specs for all three .....
SUBS -
Rec. Sealed Box Dims: 0.85 - 0.85 cu. ft.
Rec. Ported Box Dims: 1.25 - 1.25 cu. ft.
Sensitivity: 86 dB
Recommended RMS Power: 200W
Peak Power Handling: 400W
Impedance: 4 ohms
AMP -
Amplifier Type: 2-channel
RMS Power @ 4 Ohms: 250W x 2 @ 4 Ohms
THD at 4-Ohm RMS Power: 0.5 %
Bridged RMS Power @ 4 Ohms: 900W x 1 @ 4 Ohms
Speaker Level Inputs: yes
Preamp Outputs: no
Built-In Crossovers: LP
Bass Boost: 0 - 15 dB
Frequency Response: 20-20,000 Hz
Signal to Noise Ratio: >95 dB
Fuse Rating: 80 amps
DECK -
Key Features
Player Type CD
Controlled Devices CD Changer
MP3 / WMA Playback MP3 Playback
Amplifier / Speakers
Built-In Power Amplifier Yes
Built-In Amplifier Power 4 x 50 Watt
Radio
FM Presets 18
AM Presets 6
Tuner Type FM / AM
//content.invisioncic.com/y282845/emoticons/wave.gif.002382ce7d7c19757ab945cc69819de1.gif
Welcome to the forum.
Just at a guess having nothing more than the minimal info contained within your post I would say it's a voltage issue (ergo: when you have the volume up somewhat high the current being drawn by the amp is more than your vehicle is capable of supplying and consrquently it causes the equipment to shut down due to lack of power)
What kind of electrical does your car have?
How big is the battery?
Do you know what amperage your alternator is rated for?
What size cabling are you feeding current to that amplifier with?
My guess is that the deck shuts off due to a voltage problem, and the amp shuts off because the deck shuts off.
You need a multimeter for any serious troubleshooting, but make sure your head unit has a good ground and a secure connection on the yellow wire.
ive had a system in this car since 2002 and it was good then ... i could turn it up all the way and no problems ... this started happening a year ago .. and i cant seem to fix it ... one day i had the volume up and it just started turning off ...
insaini
insaini
Ontario Canada
insaini
