Decision making time.
  • 6
zSnb
I've been reading alot of threads on this forum and i've finally come to one conclusion on a set of components. Im going with the CDT Audio CL_61A-25Pro's. But now i cannot decide on which tweeter i want to go with. TW24 or TW25??? Silk......or titanium? I dont want to go titanium if it is too harsh. I've heard alot of good things about silk dome tweets. But on the flip side i hear that metal dome tweets are much more precise and sound more detailed. Is it true? Help me out guys.
I have the same comps and i am using the silk tweeters and love how smooth they are even when i blast the music. you should love the way they cl61 sound with silk tweeters.
whatever you do, dont do this
In that airspace you could go ported with th Si SQL 12@$369, hands down the best option in a 1.41 ported box. With 1000 watts RMS and 92 db...
16
811
My 2 - 15" wedge box is around 5 cubes net with 80 square inches of port. My 4 - 8" wedge box is 3.69 cubes net with 43¾" square inches of port.
393
So I'm split what I should do...I can buy a 2 channel to run my tweets for a 2 way active up front or I can buy a pair of 3-4" mids (off parts...
840
I had this same issue with my Sony. When I first got it I had speakers hooked up to the head unit without amplifiers and it worked fine. Once I...
zSnb
zSnb
North Ridgeville, Ohio
skydeaner
    May 16, 2024
    May 16, 2024
