Decision: Kicker vs. Hifonics
wevie
Currently looking at two options for new amps:
First, system is basically two CVR12's each in 2.85 ft3 slot port enclosures. They are DVC4's wired parallel/series for a total 4 ohm load. Currently using multi-way 6x9's for mid/high but want to upgrade to decent components.
Now, two amp options I'm looking at:
Kicker ZX1000.1 and ZX350.2
or
Hifonics Bxi1608 and Zxi6008
There is a SLIGHT monetary advantage to the Hifonics, but it isn't enough to take into consideration.
Also would like the option of going to 3 CVR's wired series/parallel for a total 2.66 ohm load.
Hopefully I've given enough information. If not, just ask!
HIfonics has always had great amps - there newer amps have dropped off a little but definatly not enough to call them worse than kicker. Im not saying they are better but there not worse. I would do the BXi, I dont like the Zues Series. You wouldnt be disappointed either way.
The BXi listed is a mono block for the subs. The Zues listed is a 2-channel for the mid/highs. I'm anal about having amps that cosmetically compliment each other!
For Budget - well, of course the cheaper the better, but quality first. $800 is doable, but probably the upper limit. I think I can get both Kickers or both Hifonics for under $500 shipped.
kicker without a doubt. Hifonics are good for the money but kicker is much better from my own personal experience.
wevie
wevie
Iowa
Tricked
BP1Fanatic
BP1Fanatic
