deciding if i should try a 4th order???
kurrupt
hustlenomics
can someone list the advantages or disadvantages to doing a 4th order?
im looking at possibly using 4 mach 5 mj18m's run off a audiopipe 3000.
the box will be in the bed ported through the rear window.
i also thought about 6th order since i have my whole bed that i could use which is a 8ft bed.
i think you'll enjoy it all the enclosures output will be directed in thru the rear window
(if built right)
hit up 80 fpr a design and drive to my shop to build it lp.s. go 4th
iv never thought of doing a 4th before im just looking for something to kill some lows im not to worried about numbers.
anyone else have any comments
Are you using a camper shell and removing the rear window? If your not removing it then how big is the opening?
If your removing the rear window, you may be better off with a ported clam shell if the opening is big enough.
there will be a camper shell with the rear window removed
kurrupt
hustlenomics
kurrupt
neenah,wi
jdawg
michigan born
    May 14, 2026
michigan born
    May 14, 2026
