Decent sub/amp combo for ~$200-250?
im sorry, i dont know shit....which one do i get?
10K.14 10" high excursion small box driver. 325RMS/650peak. Single 4 ohm $225.00 > $129.00 -
10K.44 10" high excursion small box driver. 325RMS/650peak. Dual 4 ohm $225.00 > $129.00 -
I've got a Clarion dxz735mp if that makes a difference
Those are the newer model ones, they aren't available till June...
If you can squeeze a 12" back there, look into the Adire Audio Shiva-
http://www.adireaudio.com
Also, what are the specs on the amp?
doest a shiva need ALOT more power and a bigger box then a K?
i know in the back of my silverado for a 1 sub setup i could have done like a 2 cube box but still a shiva needs tons more power
JBL BP300.1 Mono Digital Amplifier
$ 149.00
CLASS D MONO BLOCK AMPLIFIER
1X150 WATTS @ 4 OHM-THD: 0.1%
1X300 WATTS @ 2 OHM-THD: 0.1%
1X300 WATTS @ 1 OHM-THD: 0.1%
BUILT-IN VARIABLE LOW PASS ELECTRONIC CROSSOVER
BULIT-IN VARABLE BASS BOOST
SENSITIVITY: 100dB
2- LED MONITOR, PROTECTION AND POWER
FREQUENCY RESPONSE: 20-500 HZ.
DIMENSIONS: 10-3/4" X 8-5/16" X 2-11/16"
Originally posted by Mac11 doest a shiva need ALOT more power and a bigger box then a K?
Shiva takes 600 watts...can be put in very small boxes as well...
JBL BP300.1 Mono Digital Amplifier $ 149.00
SENSITIVITY: 100dB
Errr...oops, thought the Clarion you said was an amp and not a h/u, my fault...
If you can fit the 12", go with a Shiva, if not, maybe take a look also at the ImageDynamics IDQ series-
http://www.imagedynamicsusa.com
in my box, the shallowest depth is 5", it says the type R is 5-15/16" deep, the bottom of the cutout is 6.5" deep, maybe it'll work.
atldc
atldc
ATL
lilcreeper
