jaross
I listen to hip hop, jazz/vocal, rock, and electronic mostly. I have had a "15 rockford fosgate punch running with stock speakers in different cars, at one point with 2,000 watts going through it. I am over the ridiculous "disconnected" sounding bass that you get from a sub so I do not plan to run one. On top of that, I could use to save the space and weight. I am thinking that some hitting rear deck speakers should be plenty for me. I don't have any budget yet but I am thinking I would like to spend no more then $100 for all 4 speakers. I am thinking I will buy the rears first to save money.
My car has "4 in front and 4x10 in rear stock. I am told that 6x9s are an easy fit and maybe better then the 4x10s in the rear.
I just purchased this:
Sony DSX-S200X Digital media receiver at Crutchfield.com
I also have an Eclipse 3650 amp, specs for which are:
Can I bridge the Eclipse for 2 more powerful channels (*do I want to do such a thing?) to just power the rear speakers?
What speakers would you recommend that come in the sizes needed? I don't need anything super fancy. I don't want to spend a lot of money, but surely for $100 or less there should be something worth purchasing over the stock '80s speakers.
The car is wired for an amp in the rear already, though the power wire is only like in between 1/4 and 1/2". I don't really want to put the effort into running wires back to the front from the amp so I was thinking of having the head unit power the 4" speakers in the front.5/4 channel power amp with channel flex crossover plus subsonic filter
40x4 at 4 ohm
120x1 at 4ohm
2ohm stable design
channel flex xover
Adjustable high-pass frequency (50-200hz for front)
high-pass frequency (120 for rear
Adjustable low-pass frequency (50-200hz for subwoofer)
