Decent 6.5 comps
I'm actually in the market also! lol
Same price range looking for no more then $200 (net price)
The ones i been look at are.
Infinity Kappa 60.9cs
http://www.sonicelectronix.com/item_13969_Infinity+Kappa+60.9cs.html
Polk Audio MM6501
http://www.sonicelectronix.com/item_15059_Polk+Audio+MM6501.html
MB Quart PVI 216
http://www.sonicelectronix.com/item_13942_MB+Quart+PVI+216.html
Kicker KS650.2
http://www.sonicelectronix.com/item_11516_Kicker+KS650.2.html
JL Audio XR650-CSi
http://www.sonicelectronix.com/item_1607_JL+Audio+XR650-CSi.html
Its a big selection but im just looking for exactly the right way to go.
My setup is going to be backed by a 1600Watt 4 Channel Amp.
No sub-woofer.
Looking for loud sounds, good with all genres and something that can really listen to without my ears hurting from distortion.
Aren't the answers almost always the same now?
The top listed are usually:
1) PPI 356CS - $140
2) ID CTX65CS - $180
3) Morel Tempo 6 - $250 (Tempo 6x = $220)
4) Hertz HSK-165 - $280
(3 and 4 will be over your budget //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif)
Well in my case the PPI Would be way over powered. also 89dB is a little low for me.
How about the ones i listed, anyone have any input on them? Any comments or experiences?
So none of the ones I listed you guys would recommend? Ppi the way to go?
What amp and are you going to use all four channels for one set? How many watts RMS per channel (@ 4 ohm) is the amp rated? The PPI set will take a lot more than what they are rated. People are running them here at 200+ RMS. I'm running 80 watts RMS to them and I want to do more.
Why are you not considering Alpine? I have heard the Type R set compared to some of the ones you listed and I thought they sounded better. You could get the Type X for under $200 which is even better. Have you listened to the speakers?
I think the PPI set is the way to go at this price point but I have a set and I'm biased.
TheFiverMan
TheFiverMan
Louisville,ky
Papermaker85
