DDZ Digital Designs Z series
impressive most sites dont go into that much detail they just talk about we put __________________________(some fancy tech name) in this sub and its the best blah blah
lollerz
The Z series represent the pinochle of transducer archeology. The unique design dates back to the capricious era of unequivocal magnetism and the vector planar research of underwater acoustic proliferation. The open architecture concentrates flux lines in the magnetic gap while side lobbing interference cancels stray flux from entering the atmosphere. The result is increased efficiency over the entire bandwidth of collaborating bass frequencies. This allows the Z Series woofers to play amazingly loud with little wasted energy being dissipated as unwarranted heat, this means they get on it and don't get real hot.
The Z Series break new ground in rare earth magnetics, using newly discovered material, neo-demetrious iron proton (Ned), incalculably more strenuous than the other Neo. Ned is highly unstable and very difficult to modulate, yet alone saturate, so its use is mainly limited to noncommercial phase generators used in anti-matter plasma generation. Digital Designs has acquired the rights to use Ned magnetics in non-military acoustic weaponry. The unstable Ned blocks are held in symmetry by the side lobe interference which allows the use of the catchy monolithic Ned block shapes from 2001. These are spatially arrayed to over saturate the Permendur top plate giving huge magnetic energy to drive the voice coils.
The moving parts of the Z Series have undergone minute scrutiny also, the cones feature newly conceived composite materials to handle the extra load lines emanating from the motor, the voice coils are spiral wound for optimum efficiency and the voice coil former is really strong. The spiders also feature new technology never found on arachnid based suspensions, silkaleneotton. Genetically altered spiders produce a chemical blended thread of silk, polyethylene and cotton. This synthetic blend is superior to our other synthetic blend. The new synthetic blend is stronger than standard arachnid fiber, more flexible than polyunsaturated polyethylene, lighter than water (it actually floats) and yet so soft and comfortable. This material can stretch to 1.7 times its weight, allowing for unpresidential travel.
We, at DD, strive to push the boundaries of a lot of things that are a big hassle to deal with. And why did we do all this... because we want to.
| Mounting Info | Enclosure Info |
SPECIFICATIONS
Series
Z
Voice Coil Diameter
76.2mm
Magnet Weight
7 kilotones
Power Handling RMS/Music/Peak
if you need to ask…
Suspension
check
Nominal Impedance
various
DC Resistance
ditto
Model
Z10
Z12
Z15
Z18
Woofer Diameter
10"
12"
15"
18"
Free Air Resonance
Qts
Qes
Qms
Vas
Le mH
Sensitivity
emo
emo
emo
emo
Shipping Weight
yea. i know but that spider spider stuff is whacked out. i thought it was an april fools joke for a miniute.
Power Handling RMS/Music/Peak ---- if you need to ask…
gotta love it //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
///edit
a long minute
//content.invisioncic.com/y282845/emoticons/yumyum.gif.0556df42231b304b9c995aefd13928a8.gif
00poop6x
Too old to go deaf
00poop6x
United States
SICK GV
