DD9515G + opti6000d daily
hurricanes0688
Well the speaker is dual .5 so its gonna be running at 1 ohm daily off the opt6000d. How many watts could i safely give the 9515 daily would u think. I tihnk that amp does close to 7k rms at 1 ohm. The enclosure it will be in is 4.0 cubes at 35 hz. Keep the gains conservative is what im thinking but what could i give it daily without running into problems...
let me see if i can find the bench results they are on ROE
Corey anderson benched it, 3584 at 5.1 ohms...and he said 6k+1 ohm also its the same board as the SS xxx10000d
i wouldnt put 6k on it daily, not that that things gonna put out that much but anyways......i had 2 vr2000d's one per coil, sub loved it, now i got z1 on it and its deffinatly louder...... already an ez 1.6db w/o playing with it
Why not do it?//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
You can always turn it down and keep the signal clean.
Hell, I run 3515E's on 20.1's daily w/ no trouble at all. I'm not slamming all out 24/7 though.
Just keep your voltage up and watch that sub. If you cant tell when you are giving it too much, you should not own a sub/amp like that. You can easily fry that sub w/ that amp, but if you know what you are doing you will be just fine.
ABOVE ALL, KEEP THAT SIGNAL CLEAN!
hurricanes0688
hurricanes0688
Cleveland
savagebee
