DD Sub Woofers
One for each coil or one for each sub.............either way you may want mo powa for the 9515 deffiantely if for each sub.
First off .. YES a DD9515 is a GREAT sub...
I am not sure that you know what getting this sub really means.. You are going to have to get an amp that will cost you ATLEAST $350 +++
1/0 G wiring, a new alternator, and do the BIG 3...
Getting a sub with this much power will cost you a lot more than you think..
**Just something to think about**
Quoted for truth.
I had a 3515 off a PPI 1000 mono and it was barley moving and had that underpowered muddy-ness to it. Then I stepped up to the MMatts 3000w and the 9515 and it was awsome, and that woofer could have taken another 3000 i bet. You might not need a new alternator, I ran 2 batteries and it never had a problem, but if you can swing an alternator, f-yea get one.
yea im with loaked on that , ive had big amp in my car with no probs, i got a stock alt and the batteries in my sig, i just charge them here and there to keep them topped up.....
also if your gonna buy a 9515 and you see what that cost , the 300 for an amp should be expected for somethng decent ...... not saying you cant find something for less but that statements just not true
A local guy had a 9515e in 4.5 net ported tuned to 35 hertz with a JBL BP1200.1 on it in his Thunderbird, and it was loud. It probably could have used another amp on though, it barely moved.
Kef
Before I start putting thind together I must find a altenator that gives at least 250or more. Im all open ears to anyone.//content.invisioncic.com/y282845/emoticons/verymad.gif.3f39c5c2fd57527b671fad3efdfac756.gif
Stock 130 amp for now. I have 6 group 31 batteries in my truck. I drop to 12.8-13.0 volts on burps so it is not too bad. I will be adding a 275 amp alt very soon. I am running 8800 watts rms though.
373
401
541
642
Kenyon325
Kenyon325
Austin,TX
02parkave
    May 24, 2024
    May 23, 2024
