SOLD Dd S4a 4 Channel Amp Fs/ft
bogiejoe1
vlx inside nuf said
listing up a very nice dds4a
the amp is about 3 months old and was used for maybe a month of that time
i have the box manual test sheet and org shipping box
price shipped from dd is 600
im asking 425 shipped
trades maybe zapco ck stuff pm offers plz
SPECIFICATIONS
Series S
Input Sensitivity 0.2V - 8V
Variable High Pass Filter 20 Hz - 500 Hz (200 - 5 kHz) at 24dB/Oct
Variable Low Pass Filter 50 Hz - 500 Hz (500 - 5 kHz) at 24dB/Oct
Clipping Display LED
Tested Voltage 14.4
Tested THD 1%
Model S4a
Cont Power at 4 ohm 100W x 2ch + 200W x 2ch
Cont Power at 2 ohm 150W x 2ch + 300W x 2ch
Damping Factor >550 @ 2 ohm
Cont Power at 1 ohm Must use xtra fans
Cont Power at 4 ohm Mono
300W x 1ch + 600W x 1ch
Dynamic Power 400W x 1ch + 800W x 1ch
Efficiency thru Output >64%
Dimensions - mm 420L x 232W x 63.5H
Dimensions - inches 16.54L x 9.13W x 2.5H
Signal to Noise
couple pics ill get better later
104
351
10
732
Slapz are sfb clones from my understanding. What I was pointing out is how much info slapz gives about their amps 😂
35
Thanks for that. Good point about the chimes, I 'll have to check. My thoughts were that a true center channel could serve to raise the sound...
433
bogiejoe1
vlx inside nuf said
bogiejoe1
delaware,ohio
bogiejoe1
    May 31, 2024
    May 24, 2024
