SOLD Dd S4a 4 Channel Amp Fs/ft
bogiejoe1
vlx inside nuf said
listing up a very nice dds4a
the amp is about 3 months old and was used for maybe a month of that time
i have the box manual test sheet and org shipping box
price shipped from dd is 600
im asking 425 shipped
trades maybe zapco ck stuff pm offers plz
SPECIFICATIONS
Series S
Input Sensitivity 0.2V - 8V
Variable High Pass Filter 20 Hz - 500 Hz (200 - 5 kHz) at 24dB/Oct
Variable Low Pass Filter 50 Hz - 500 Hz (500 - 5 kHz) at 24dB/Oct
Clipping Display LED
Tested Voltage 14.4
Tested THD 1%
Model S4a
Cont Power at 4 ohm 100W x 2ch + 200W x 2ch
Cont Power at 2 ohm 150W x 2ch + 300W x 2ch
Damping Factor >550 @ 2 ohm
Cont Power at 1 ohm Must use xtra fans
Cont Power at 4 ohm Mono
300W x 1ch + 600W x 1ch
Dynamic Power 400W x 1ch + 800W x 1ch
Efficiency thru Output >64%
Dimensions - mm 420L x 232W x 63.5H
Dimensions - inches 16.54L x 9.13W x 2.5H
Signal to Noise
couple pics ill get better later
im using it to run highs lol, i have a vlx 400 , im trying to get the splash series that also game from you i love the way it looks. i pick up his dd 9515's last night. I was going to get that s4a from our friend but he needed the money in paypal so he could get those sundowns from you.
107
353
10
734
Slapz are sfb clones from my understanding. What I was pointing out is how much info slapz gives about their amps 😂
35
Thanks for that. Good point about the chimes, I 'll have to check. My thoughts were that a true center channel could serve to raise the sound...
436
bogiejoe1
vlx inside nuf said
bogiejoe1
delaware,ohio
bogiejoe1
    May 31, 2024
    May 24, 2024
