Sold DD Component set, Type X component set
dacheatham
DDCS 6.5 Component SetSPECIFICATIONS
Model CS6.5
Diameter 6.5 in
Frequency Response 43 - 20kHz
Sensitivity 90 dB (1W/1M)
RMS Power handling 125W per CH
Peak Power Handling 250W per CH
Model T-2
Diameter 25 mm
Frequency Response 1,500 - 25,000
Sensitivity 93 dB (1w/1m)
RMS Power handling 50w ea
Peak Power Handling 100w ea
Item is new
Price: $130 shipped
Alpine Type X 6.5 set6-1/2" 2-Way Component System
Custom Cast Aluminum Frame
Airflow Optimized Dual-Flare Pole Vent
Integrated Spider Landing & Heat Transfer Plate
Low Resonance Multi-Roll Surround
Wood Fiber Cone
Phase-Integrated Dustcap
1.1" Soft Dome Tweeter
Ultra High Quality 2-way Crossover
On/Off Axis Compensation
Bi-Wire Input and Selectable Tweeter Attenuation
4-Layer Copper Clad Aluminum Wire on Glass Fiber Bobbin
Braided Low-DCR Tinsel Leads
FEA Optimized Motor Structure with CRC/T-Drive Geometry
Gold Plated Terminals
High Grade Strontium Ferrite Magnet
High Quality Synthetic Black Spider
Integrated spider Landing & Vented Heat Transfer Plate
Non-Resonant Suspension Coupling with Reinforced Edge
Single Voice Coil Design
External Crossovers Included
Speaker Specifications
Speaker Size 6-1/2"
Design 2-way Component System
Peak Power Handling 300 watts
RMS Power Handling 75 watts
Sensitivity 87 dB
Frequency Response 35 - 60000 Hz
Impedance (per voice coil) 4 ohms
Top Mount Depth 2.8"
Bottom-mount depth N/A
Cutout Dimensions 5.2"
One of the cone has a slight wrinkle in it. There is no mounting hardware for the tweeters. I will either keep these or the DD's, depending on if the other sells.
Price: $140 shipped
http://www.caraudio.com/forums/buyer-seller-feedback/460905-dacheatham%3D-great-seller.html
dacheatham
dacheatham
Russellville, Arkansas
dacheatham
