dd audio 3518 box
Oh I know lol... that's why I'm stalled where I'm at now. If I'm gonna go through the major hassle of pulling the box to tweak amps, it gonna get a huge upgrade while it's apart. And that's big money I don't feel like spending right now lol
Sounds like a plan //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
9518g on a 2010 M2a. Need more power for sure. And a 3rd 6" aero
Either a ts 2.8kw or another m2a strapped at 1 ohm. And a bigger alt and batts... and then... and then... and then lol
The new J and K use a 3.35" coil that longer so they have a higher qes and higher mms. It's a street beat woofer now and the 9900 is gonna be the bigger spl based sub.
That being said the 95 with the featherweight cone and supercharged will be be a spl based design but for the money the 9900 will be as loud for about 200 bucks less
List your amp/load and music tune/preferences goals... decaf tune?.. low daily?.. hi-daily?.. Spl?.. and someone will help... music tastes matter so say what your goals are... to slam, sub hard, all around, rock or pure SPL...
DD M3B, daily@1omhs
Sent from my VS987 using Tapatalk
DD M3B, daily@1omhs
You need at least 6kw. I'd recommend a larger box and more port area though for sure.. give me some measurments and the sub model. I'll draw up a design for you with a cut sheet for 20 bucks and if you don't like it I'll give you you monies back.
A Link would be very helpful. Id be interested in taking a look at some gear
174
Excellent like new condition, with minor blemishes. DSP plus 8 channel amplifier in one. $1299 shipped. $1799 plus tax brand new
160AH lithium that supports a 12K system is pretty lofty! I've seen dual 24's or quad 12's that will do this. Most of what 've run across is dual...
283
Jose_loera
Jose_loera
Phoenix
Papermaker85
