dd 9915 for daily?
I've built a few boxes for guys who run them daily. Usually 4 - 4 1/2 cubes @ 35Hz. One was getting around 1500watts, the other over 3000. Both sounded good and slammed on the lows...
well if i got one, id be running 2600@4 strapped...how do you think that would do?
It likes a lil more power,but it will still slam with that power.The composite cones really increases sq as well as has better roll off than the paper cones.The lows are killer of cousre,tune to 40hz.
I had a 9917 tuned to 35 hz on about 2200 rms in a 9 cube box strictly for daily. It did a 143 on the TermLab with only one little stinger battery, voltage sitting at 13.7 before burps, and a stock alternator. So it'll be loud. Granted it sounded like *** at times, but it was perfect for me because I just wanted it loud.
Thats why it sound like ***,box it way off,6-7cubes 120-140 sqin of port @ 40hz and ur set.
what kind of vehicle?
9cubes? jeez
A friend of mine had two 9917's in around 9 cubes in a 91 Mustang hatch and it hit HARD on the lows. Did a 152 on the TL with 4 MTX 1501d's. Sounded pretty good for daily.
You should have no problems with running 9915's daily. My other friend had 4 in a wall and would do 54's on the TL with a JBL Crown 6000. His were in 5.5 cubes each tuned to around 35 hz. Hearing his truck is the reason I now run the same subs. He got 155 and change when he had four Hifonics Colossus amps on them, but had problems with the amps on a regular basis, so they came out.
You should be good to go with 4.5 - 5.5 cubes @ 32-35 hz with your power.
how would this sub do for daily? i dont really know that much about DD. right now i would like to find something that will dominate the lows, but im just not sure this sub would do that. also, how much power would i need for daily?
re 15 xxx or
alpine type x 4 da lows.
regal8r
I <3 my CRX
regal8r
Lincoln, NE
60ndown
