Dd 15 making popping noises wen turn the gain up??
My digital designs 15 9500 old style makes some popping weird noises wen i turn up the gain but if i lowered it down the noise goes away..my gain is set passing half way more then that startd making tte noise wat mite b the problem help plzz:( im runing a alpine mrp-650 gain pass half way bass eq 0 frequency 75hrtz all stock electrical
U tink sooo I pushd the sorround and no noise and the woofer still stiff I was told maybe my electrical on my car that amp was making the noise shorting out on power??
Ur probably clipping the hell out of it and its bottoming out ...I doubt the 650 watt alpine is taximg ur cars electrical that bad ...that amp and sub combo is a real head scratcher ..either get a sub more suited for the amp ..or get a bigger amp more suited for the dd after a possible recone...this will also have to be followed by upgrades ti the electrical system
Yea I thinksoo wat maybe causing the clipping to the sub and I am upgrading eletrical all zero gaugr and battery on the back and a shark aaudio 2500 amp
What kind of box do you have it in? If its a pre-fab ported box....tuning is most likely way to high allowing the driver to bottom out when you jack the gain.....
And near 100% positive you are clipping the hell out of that amp..
Soooryy gguyss but the dd 15 just died today I switch amps I got me a jbl gto1200.ii n couple of songs it popped //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif any dd recones?? Any idea were to get them its a 9515 d2 help ppp
851
I had this same issue with my Sony. When I first got it I had speakers hooked up to the head unit without amplifiers and it worked fine. Once I...
Looks like half a dozen other makes/models on the market, rebranded . The shallow mounts look like they’re made by Pioneer but what the hay, one...
I think it worked .just odd bc it's brand new but I appreciate it man. haven't had any problems yet
Is that speaker in the existing rear deck? Are you running a sub in the trunk?Do you have that speaker on an amplifier?Are you using a stock HU...
Trasero05
Trasero05
Phoenix
mylows10
    May 18, 2024
    May 18, 2024
